Print at Sep 9, 2026, 11:11:59 PM
Posted by Keet at Mar 21, 2024, 1:15:25 PM
Re: File / background limit
You don't need to change the code to enable drawing a wall of 128m. Changing the code from mm to m also means you loose the fine tuning of measurements by mm. In the desktop version you can simply draw a wall of 128m, no problem. Besides that, those 128 meters are probable composed of multiple wall parts so even with a smaller limit you would be able to draw the building.
