Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Hide elements from Map but not 3D View » » » » Post: Re: Hide elements from Map but not 3D View |
Print at Sep 10, 2026, 12:12:34 AM |
| Posted by Keet at Mar 21, 2024, 10:14:50 AM |
Re: Hide elements from Map but not 3D View There is a neat trick to handle this. On each object you can set the property "Part of base plan". Some objects are part of the base plan by default like walls, floors, doors, and windows. This property does nothing until you lock the 2D plan. You can lock/unlock with the little lock in the top left corner of the 2Dview or Ctrl+alt+L or right click in the 2Dview and select from the context menu. When you lock the 2Dview all objects that have this property set will be locked which means that they don't move, can't be selected, and don't interfere with other objects you are moving around. If you want to move or edit one of these objects just unlock the base plan. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 10, 2026, 12:12:34 AM |
