Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: How do I get rid of the white outline around the photos on the boxes in YafaRay? » » » » Post: Re: How do I get rid of the white outline around the photos on the boxes in YafaRay? |
Print at Sep 26, 2026, 8:32:00 PM |
| Posted by Keet at Mar 16, 2024, 10:28:35 AM |
Re: How do I get rid of the white outline around the photos on the boxes in YafaRay? Then I'm afraid I don't know what else you can do. If you search the net for white line around 3D object you will find a lot of references. It seems to be a very old and common problem, often found in relation to game development. There are a few very technical explanations and a lot of tries to solve it. But other than the aliasing (which I found with a quick search) I found no other solutions you can try within Sweet Home 3D. Maybe if someone is capable of implementing the Cycles renderer it can be solved. It's free and open source so it fits Sweet Home 3D. It's the best available renderer used by Blender. Even professional studio's use it. I don't know how to do it but you can try to render a photo in Blender and see if the same problem occurs. Either by using Cycles or YafaRay. You should have a few more options to set in Blender that might make a difference. Once you know if a specific setting for YafaRay does solve the problem you can ask EnkoNyito if he can add it to the AdvancedSettings plugin. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 26, 2026, 8:32:00 PM |
