Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Custom 3D Model being imported without texture » » » » Post: Re: Custom 3D Model being imported without texture |
Print at Oct 5, 2026, 11:17:03 PM |
| Posted by [email protected] at Mar 15, 2024, 7:05:31 PM |
Re: Custom 3D Model being imported without texture As always, thanks Keet. Too bad...not so much for the impossible movement of the shutters (this can always be done manually without the need to tie the objects...not nice but doable) but for my project (still mysterious to you) of a pull-out table that can be rolled up in as if I understood correctly, driving a plane that rolls up on a hinge (done) and slides along a rail (done) cannot be pushed into action by anything, much less making movements always in axis with the rail.....on the rail it can only slide and the shape created manually by its rolling will slide. Unfortunately there is no manual solution to this that works. For Puybaret...... "Very nice, Veroniq is going to love your shutters. She requested such models in the past wink Please submit them in 3D models tracking system." for now Veroniq will have to be satisfied with what is attached, the models as I explained are still experimental (to be refined and perhaps translated (the terminology is ITALIAN), there are only visual objects to be removed (for example only in some residual opening keys which are displayed as objects but not used in motion), some imperfections in the stops (hastily built with cylinders to have only a logical shape) etc etc) |
Current timezone is GMT Oct 5, 2026, 11:17:03 PM |
