Print at Sep 21, 2026, 6:43:48 AM
Posted by Puybaret at Mar 15, 2024, 6:28:02 PM
Re: Mirrored furniture deformation problem
I think I found an acceptable tradeoff: I won't change the current behavior when the user select the Mirrored shape check box, i.e. such an object will keep the same coordinates. If the object is an already widely opened door, the door frame will move on the wall, and in your case, the wardrobe box will move.
But when you deform it afterwards, the parts which didn't move will keep the same position whether the object is mirrored or not. This fix will be available in the next version.
