Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Video render works first time only » » » » Post: Re: Video render works first time only |
Print at Aug 26, 2026, 10:13:23 AM |
| Posted by Puybaret at Mar 13, 2024, 11:26:37 AM |
Re: Video render works first time only It looks very similar to Snmavronis' issue, but the correction I programmed won't work in this case because the file chooser used in the advanced video rendering plug-in is programmed here to select a folder (hint: there's an error in DirectoryChooser), and I didn't make corrections for that case. I'm not sure why Enkonyito programmed this dialog box but requesting a folder shouldn't fail anyway. Let's try first to understand how it really happens in your case. The strange thing is that it works the first time. Do you select a folder different from the proposed one the first time you generate a video? If yes, what files does this folder contain and does it still bug the second time if you don't change the proposed folder? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 26, 2026, 10:13:23 AM |
