Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Automatic dimensions addition » » » » Post: Re: Automatic dimensions addition |
Print at Sep 20, 2026, 11:18:12 AM |
| Posted by Keet at Mar 5, 2024, 2:59:03 PM |
Re: Automatic dimensions addition Trying out plugins is very easy if you first install the plugins manager: https://sourceforge.net/p/sweethome3d/plug-in.../PluginManager-1.5.3.sh3p Once that is installed you can just select a plugin you want to add, update, or remove. You can read more about it here: http://daniels118.altervista.org/sh3d/pluginmanager/ There is no plugin to color walls in the 2Dview but there are a lot of other useful plugins. You should at a minimum install the advanced edit plugin and you will probably want the Roof and Staircase generator plugins too. The Pan3DView plugin gives you a better 3Dview experience. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 20, 2026, 11:18:12 AM |
