Print at Sep 20, 2026, 10:19:33 PM
Posted by Keet at Mar 1, 2024, 8:27:59 PM
You might find this site helpful: https://www.colorhexa.com
It has all color codes for use in your objects. You can enter a name like "gold" or "ivory", or a #hex code in the search box to find your color.
It also supplies the XYZ codes for the color, the codes as used in MTL files. No need to convert a #hex code to those numbers if you want to enter a color code directly in a MTL file for the Ka value.
The site also provides alternatives, colors that are slightly different but could be a better fit for your objects. And finally it also shows scales with different shades, tints, and tones for a color.
