Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Deformation problem - Bug or by design? » » » » Post: Re: Deformation problem - Bug or by design? |
Print at Sep 26, 2026, 11:15:10 AM |
| Posted by Keet at Feb 25, 2024, 9:42:26 AM |
Re: Deformation problem - Bug or by design? Any info on this? It only seems to be a problem when the '_and_' part is added but I can't think of any logical reason why this can't be imported. @Emmanuel: Is it a technical impossibility or does the current programming perform a check that doesn't allow import? And if it is a programming check can this be changed to allow import even if the deformation for the object will not work? Allowing import of an incomplete deformation will make it possible to create objects that have a hinge_2_ that can be added to doors that already have a hinge_1. Export/import of the combined objects will then result in a fully functioning door with chained deformations without having to manually edit the object file to add the '_and_' part. In other words: It will make it possible to create fully prepared building blocks for furniture creation. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 26, 2026, 11:15:10 AM |
