Print at Sep 20, 2026, 10:19:13 PM
Posted by Keet at Feb 21, 2024, 3:53:13 PM
Re: getting the level on levels
It probably has to do with the numbers you are using.
Read up on levels here: https://sweethome3d.com/userGuide.jsp#addingLevels
and here for levels below 0: https://www.sweethome3d.com/blog/2022/04/21/h...basement_to_a_design.html
Floor thickness is exactly what it says: the thickness of the floor. The lowest level has a floor thickness of 0. You can see that because the setting in the modify level dialog is grayed out.
