Print at Sep 21, 2026, 6:21:08 PM
Posted by NIMAN at Feb 19, 2024, 12:35:02 PM
Re: page size / sheet size image centering
Probably because the printer Firefox was set to had A4 as the default.
Apparently not.
I repeated as follows:
in SH3D Page setup (Ctrl+Shift+P) - format size A0 (i.e. 841 mm x 1,189 mm) was not available so I simply chose size A4, scale 1/10.
in SH3D Print (Ctrl+P) I changed from the pre-selected hardware printer to kept CutePDF then selected "properties" followed by Advanced" and selected ISO A0 from the drop down list and printed.
Then, prior to opening the file in Firefox, I set the Firefox destination printer as "CutePDF Writer" and paper size to "ISO A0" - when opened the wall still appeared across multiple pages.
It therefore seems key (in Windows 10 at least) that A0 is selected in the first SH3D Page setup step.
Assuming the PDF printer didn't scale a little while creating the PDF because of margins this should be correct. But I suspect a little scaling was done to fit within the margins. The same for the physical printer, it most likely can't print to the paper edge so a minimum margin is needed. It will be close though.
Appreciate this Keet - printing in SH3D no longer seems like a problem applause
