Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: SweetHome3DJS - Porting plugin - ARM architecture support » » » » Post: Re: SweetHome3DJS - Porting plugin - ARM architecture support |
Print at Sep 10, 2026, 4:15:38 AM |
| Posted by adizanni at Feb 18, 2024, 1:12:53 PM |
Re: SweetHome3DJS - Porting plugin - ARM architecture support Always related to this project. I think that I got from other posts that the JSP code is only compatible with JAVA 1.8. When I tried JAVA 21 I found only one problem: Unable to make field protected static final java.lang.String javax.swing.undo.AbstractUndoableEdit.UndoName accessible: module java.desktop does not "opens javax.swing.undo" to unnamed module @1cc19e8a in the WriteHomeEdits.jsp file. Even following all stackoverflow suggestions to change some JVM parameters and allow reflect action, it does not work. I have a problem with the fact to stay in 1.8: I'm packaging a container with tomcat and jdk, the only based image still supporting 1.8 is quite outdated and brings a lot of vulnerabilities. Is there any workaround to make your code compatible with recent versions of Java ? (or maybe it is already but I'm doing the things wrong). I Thanks in advance for your support. Andrea |
Current timezone is GMT Sep 10, 2026, 4:15:38 AM |
