Print at Sep 10, 2026, 3:17:15 AM
Posted by Puybaret at Feb 16, 2024, 10:08:23 PM
Re: SweetHome3DJS - Porting plugin - ARM architecture support
Sweet Home 3D can run headless if you set the Java property java.awt.headless to true (which is probably the default value in Tomcat) and set the Java property j3d.rend to noop.
You may even need no library in that case but I’m not sure.
