Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to define multi-level hinge and rail of 3D model » » » » Post: Re: How to define multi-level hinge and rail of 3D model |
Print at Oct 5, 2026, 7:22:08 PM |
| Posted by Keet at Feb 15, 2024, 7:27:01 AM |
Re: How to define multi-level hinge and rail of 3D model Don't make it more difficult than necessary, use a cylinder instead of creating a room: Drag a cylinder in your 2Dview, resize as needed (width and depth, height doesn't matter), set horizontal rotation to X 90°. Export and import as window. Much easier than creating a circular room with walls. The same cylinder can be used as a non-window filler disk when you set its height to the wall thickness and export/import. One thing: cutting a hole doesn't work on a curved wall. The cutout will always be sqaure. by-the-way: start a new topic for a new subject. The cutout problem is not related to the topic title hinge and rail. A new relavant topic title makes it easier when someone searches the forum for a specific problem. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 5, 2026, 7:22:08 PM |
