Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to define multi-level hinge and rail of 3D model » » » » Post: Re: How to define multi-level hinge and rail of 3D model |
Print at Oct 5, 2026, 7:23:10 PM |
| Posted by [email protected] at Feb 13, 2024, 9:21:20 PM |
Re: How to define multi-level hinge and rail of 3D model Keet I explain the logic of my...ghost First I drill the wall with a position fixed to the dummy (exported in that position re-imported as a window to drill the wall), I make the walls transparent or partially transparent and export..... When I re-import it the wall will be perforated and of the desired transparency. I export the used dummy object and edit the MTL file using the d parameter 0.???????????? on the parts to be made semi-transparent. I reimport everything, I position the dummy (imported as a window) on the surface of the wall in correspondence with its hole... and I move it slightly to one side to give the sensation of a movement OUT of the wall....... I reimport and reimport .....now a mannequin moves as if it had come out of the wall to which it is attached. This is my idea....do you think it could work???? Greetings |
Current timezone is GMT Oct 5, 2026, 7:23:10 PM |
