Print at Sep 20, 2026, 9:30:59 PM
Posted by Keet at Feb 3, 2024, 6:09:24 PM
Re: Roofs
Assuming you already installed the Generate Roof plugin check out this topic describing dormers and integrating Velux windows:
https://www.sweethome3d.com/support/forum/vie...ad,11330_offset,190#60535
Don't forget to install the special window library Dorin created to integrate the windows in the roof.
That the roof is above 2 levels doesn't make a difference. After generating it's another object you can move to another level or give a different elevation. That way you should be able to place it where you need it.
