Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Trying to dock back a popped out 3D view causes program to hang/crash » » » » Post: Re: Trying to dock back a popped out 3D view causes program to hang/crash |
Print at Oct 14, 2026, 4:32:45 AM |
| Posted by Keet at Feb 2, 2024, 10:32:13 PM |
Re: Trying to dock back a popped out 3D view causes program to hang/crash The detached view setting is stored in the .sh3d file. Because of that I assume that you only have the problem with one specific home? If it is indeed only one specific .sh3d file you can fix that by editing the Home.xml file. This file is located in the .sh3d file which is a zip file that you should be able to open with any archive manager. The line in the Home.xml file that you should edit is located close to the top: <property name='com.eteks.sweethome3d.swing.HomeComponent3D.detachedView' value='true'/>Change value='true' to value='false'. There are probable five more lines after that line concerning the detachedView. They don't matter if the detachedView is set to false. Maybe one of the values in those is the cause of the problem and they should be reset if you detach again. On my Linux system I can edit the Home.xml file while still in the zip and after saving it updates the .sh3d file. If that is not true on your system you will have to extract the .sh3d file to a folder, edit the Home.xml file and re-zip. Rename the .zip to .sh3d and it should be good. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 14, 2026, 4:32:45 AM |
