Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to add walls to a room after it is "completed" » » » » Post: Re: How to add walls to a room after it is "completed" |
Print at Sep 10, 2026, 12:16:36 AM |
| Posted by LizardCobra at Jan 27, 2024, 3:44:41 AM |
Re: How to add walls to a room after it is "completed" My question was about how to add more walls after a "room" has been closed off or considered complete. While drawing, it automatically adds walls until you hit escape. After that, adding a new wall to any existing wall doesn't really join it to the room properly. A common situation would be accidently hitting Esc too soon, and it closes off with a diagonal wall straight through the room. I found that the solution to this situation is to first close off the room, if that is not already done. Then select the room outline, right click an existing room boundary, and click "Add point to room." Then you can drag the point to where it needs to be, and add more points as needed. |
Current timezone is GMT Sep 10, 2026, 12:16:36 AM |
