Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Staircase generator plug-in » » » » Post: Re: Staircase generator plug-in |
Print at Oct 5, 2026, 4:10:09 PM |
| Posted by Keet at Jan 17, 2024, 9:24:35 AM |
Re: Staircase generator plug-in One thing to keep in mind: the height of a staircase is the room height + the floor thickness. So if your level height is 2.50m and floor thickness is 20cm your staircase should be 2.70m. What I do is adjust the parameters to get as close as possible to the required height and if there is a minor difference after generating I correct that by changing the height of the staircase object. You can use two decimals in the number fileds and the calculation will use them. Just remember that the display of the number in the field will revert to one decimal (mm) once you leave the field. Using that it's almost always possible to get within a millimeter of the required height. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 5, 2026, 4:10:09 PM |
