Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: roof plugin is grayed out!? » » » » Post: Re: roof plugin is grayed out!? |
Print at Aug 18, 2026, 10:34:21 PM |
| Posted by Keet at Jan 15, 2024, 8:40:55 PM |
Re: roof plugin is grayed out!? You can delete the room after you generated the roof. It is no longer needed. You can select the generated roof instead of the room if you want to make adjustments. It will generate a new roof when you're done. If you want to save the room but don't want to see it in your plan: create a new level at the same elevation and move the room to that level. Then make the level invisible. You will no longer see the room and still have it available if you need it. An invisible level is a good place to save all kinds of objects you might need later but don't want to see in your current plan. Make sure the level is visible if you want to move furniture to it. You can't copy furniture/rooms/walls to an invisible level. edit: typo ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Aug 18, 2026, 10:34:21 PM |
