Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Bottom view: 3D view » » » » Post: Re: Bottom view: 3D view |
Print at Sep 26, 2026, 1:34:28 AM |
| Posted by db4tech at May 23, 2010, 5:38:19 PM |
Re: Bottom view: 3D view it does not matter how tall the visitors icon is set too. i want a top down view of the walls for making the walls. seeing them from a front view walking does not help i need to see the whole layout and zoom in closer to put walls so they join up nicely. Try placing curves walls yourself and see the hassle it is and how easier it is when looking at them from a top down view. Hi michellembrodeur, What you are asking for is already available in the (top right display of the Sweet Home interface) Plan view, if it helps you can zoom right in to help with accurate object and wall placement, if using Sweet Home on a Windows computer press and hold the Ctrl key on your keyboard then rotate your mouse wheel back and forth to zoom in and out, releasing Ctrl and just rotating the mouse wheel causes the Plan view to scroll up and down . Hope this helps you build your model. db4tech |
Current timezone is GMT Sep 26, 2026, 1:34:28 AM |
