Print at Sep 21, 2026, 6:21:48 PM
Posted by sjb007 at Jan 10, 2024, 11:04:40 PM
Re: Wallapproach configurable?
Ahhh... I think you have constructed your wall in a strange way. You have made the short wide bit and the long narrow bit as part of the same wall, then changed the width of the long narrow bit.
Instead, draw you outer wall as a single perimeter object. Only then, create the inner walls as separate segments. Then you can move it independently.
https://drive.google.com/file/d/187YBqjXQJVch...qRZ4otZF/view?usp=sharing
Each coloured number sequence is started as a new wall. Hope that makes sense. The blue wall can simply be extended to overlap the corner between red 5 & 6. Then using one of the two above suggestions you can perfectly align it.
(Looks like you may have already solved, but posting my response for others/posterity.)
