Print at Sep 29, 2026, 7:57:08 AM
Posted by Keet at Jan 5, 2024, 11:55:06 AM
Re: Hello All...
That won't work Hans. The eteks door frame has a sill that you can't make invisible separately so you will have to make the whole door frame invisible. That essentially removes the door and the wall will reappear. If you don't make the frame invisible the sill will also remain visible.
@Wayda
It is possible to achieve the required result in a few different ways:
1. Create a custom door frame where the sill has a separate material that you can make invisible. (See below how-to)
2. Insert a door and create the rooms. Split the wall twice and move the splits to the sides of the door. Remove the wall part where the door is and also remove the door. The rooms remain as if there was a door and there's no line since they connect.
3. Split the wall twice and move the splits where the opening should be. Remove the wall part. Add points to the room where the opening is and move them to fill in the gap. With magnetism on this is very easy because it will show a round dot at the wall/room corners. You add points to a room by selecting it and right-click on the room border where you want to add a point and select "Add point" from the context menu.
Options 2 and 3 will have a gap from floor to ceiling. If that is not what you want use option 1.
You could also use option 2 or 3 and add an elevated box for the top. This won't work very well because the same texture on the wall and the box will still look different. I recommend you go for the custom door frame. It's really easy to create. Even if you want a gap all the way to the ceiling this a better option because it makes it easier if you want to recreate the rooms because there still is a "door" to get the separate but connected rooms.
How to create a door frame with a separate sill:
• Use boxes to create a frame without the sill. Export the boxes as "Frame" and edit the obj and mtl files that are created by the export:
• In the obj file change all lines starting with usemtl to usemtl Frame. Save the obj file.
• In the mtl file remove all but the first block. Replace the line starting with newmtl with newmtl Frame. Save the mtl file.
• Import the Frame object.
• Create a sill using the box object and export it as "Sill". Edit the obj and mtl files again:
• Do the same replacements in the obj and mtl files as you did for the frame but now use "Sill" instead of "Frame".
• Import the Sill object
• Combine the Frame and Sill to a door frame and export as "OpenDoorFrame" (or another name you like).
• Import as "Door or window" and you have a door frame where you can make the Sill invisible and the Frame remains as a door opening. Making the sill invisible will still leave the door opening and the rooms should connect in the middle.
For cleanup you can remove the Frame and Sill obj/mtl files if you want. They are no longer needed.
Another possibility is to make a full frame (including the sill) and export it. Again replace all usemtl lines with usemtl Frame and in the mtl file leave only one block with newmtl Frame.
At the bottom of the single remaining block in the mtl file add the line "d 0.0". This will make the whole frame "invisible" because the line "d 0.0" makes it 100% transparent. Import it as "Door or window" of course. Now you have an invisible frame to cut a hole in a wall. You can simply resize the object to the size of the hole you want so you can use it for any sized hole you need.
