Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Process for orthographic, outlined, sectioned, images. » » » » Post: Re: Process for orthographic, outlined, sectioned, images. |
Print at Sep 20, 2026, 9:04:31 PM |
| Posted by sjb007 at Dec 9, 2023, 4:31:48 PM |
Re: Process for orthographic, outlined, sectioned, images. Hmmm. That should have worked. Daniels118 has released a fix for the non appearing dialog for the plugin. Update that, and retry. If it is still not working you will probably need to try talking/working with Daniels118 to figure out why this is failing. For detailed technical drawings I was talking about the documents that go beyond the simple external appearance/internal layout needed to get the planning department to grant permission. Maybe more technical drawings can be skipped if the job is a standard one on a standard property where the builder does the job in the standard way that he's already done a dozen times. My property is anything but standard, being a Frankenstein-like mashup of 150 year old barn, 600mm thick solid rubble-stone walls, an early '90's conversion to domestic use, and internally styled to look like a '70's caravan. Given the degree of changes to the existing fabric and structure that my current plans entail, I expect to need technical drawings. |
Current timezone is GMT Sep 20, 2026, 9:04:31 PM |
