Print at Sep 20, 2026, 8:13:13 PM
Posted by NIMAN at Dec 9, 2023, 9:07:43 AM
Re: Process for orthographic, outlined, sectioned, images.
Congratulations sjb007 with implementation in #115742 applause
So the lines need to be enabled in the parallel projection mode. Ordinarily this is done under "3D Menu > Pan 3D View Settings", and then set Outline to true. In my Linux system I'm getting an exception currently, so this may or may not work for you on Windows.
If that fails you can manually edit the config file for the Pan3D plugin. It'll be AppData\Roaming\eTeks\Sweet Home 3D\pan3dview.xml
Unfortunately, on Win 10, neither manual edit of pan3dview.xml to "true" nor using the pan 3d view settings (SH3D user interface) outline set to "both" caused any outline to appear on the Display side view - image links here for the record (SH3D was restarted after each relevant change):
both https://postimg.cc/jL3pZmVW
true https://postimg.cc/75DK1NhC
(Note, these are not the detailed technical drawings. I'll still need a pro for those.)
For the Building Control Application? is that still the case?
If so, would be interested in your pro required reasoning.
