Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Zoom problem in aerial view » » » » Post: Re: Zoom problem in aerial view |
Print at Oct 15, 2026, 10:53:22 AM |
| Posted by Keet at Dec 4, 2023, 8:48:54 PM |
Re: Zoom problem in aerial view Using camera's in a virtual visit like GaudiGalopin3324 explained is one way but it doesn't solve your problem with zooming in Aerial view. One possibility is the problem as described in the first few posts of this thread, read back to see if that is your problem too and how to solve it. There are other options. If you haven't done this already install the Pan3DView plugin . It gives you more options to manipulate the 3Dview. It is possible that you moved your 3Dview while moving around in it. Try scroll-button down and drag towards you. This should drag the view closer to you much like zooming in. That way you can also pan left and right. Read up on the other functions that the plugin offers, it has become quite advanced with newer versions. Lastly check your preferences, specifically the "Aerial view centered on selection" setting. Enabled centers your 3Dview when you select an object in the 2Dview so zooming should be easy. It has the disadvantage that your 3Dview jumps around while selecting different objects in the 2Dview. With the setting disabled you sometimes have to search for the selected object but the 3dview stays when other objects are selected in the 2Dview. I use both views depending on what I'm doing. When creating furniture I have it disabled and when designing a home I have it enabled. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 15, 2026, 10:53:22 AM |
