Print at Aug 25, 2026, 11:49:34 AM
Posted by Puybaret at Nov 30, 2023, 7:50:14 PM
Re: Port SweetHome3DJS on docker
So for now do not compile on linux?
Just install subversion, ant and nodejs packages, set JAVA_HOME environment var and follow instructions in README.TXT (if you get a "tsc command not found" error, follow also this tip). I just tried again and it worked.
It is possible to contibute to developments?
What do you have in mind?
