Print at Aug 25, 2026, 12:13:33 AM
Posted by Keet at Nov 27, 2023, 10:44:47 AM
Re: the white color on the boxes looks different. Can this be fixed?
You can try and export both objects that should have the same white but appear different. Then compare the numbers in the .mtl files of the two exports. If they are exactly the same the problem is in Sweet Home 3D or the rendering engine. If they are different, copy one of the .mtl white sections over the other to make them the same. Import both and see if they are still different in appearance.
