Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Transparency value in color selector » » » » Post: Re: Transparency value in color selector |
Print at Sep 14, 2026, 12:48:10 AM |
| Posted by Keet at Nov 21, 2023, 10:43:30 AM |
Re: Transparency value in color selector Can I revive this wish? It's annoying to always have to edit the mtl file to change transparency. Even worse, you have to re-import the object before the transparency change is visible and you have to do it again with the next transparency change. If I want to allow the user to switch between transparent glass and a solid color I have to create a copy of the solid object with one with transparency and place both at the same position. Then the user has to make one of them invisible to switch between them. Simply being able to set a tranparency between 0.00 and 1.00 would remove the need for using double objects making the end product smaller as a bonus to the easier handling. Using textures is not a valid alternative for this. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 14, 2026, 12:48:10 AM |
