Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: House "build" in step by step » » » » Post: Re: House "build" in step by step |
Print at Sep 21, 2026, 11:51:30 AM |
| Posted by Keet at Nov 21, 2023, 9:35:44 AM |
Re: House "build" in step by step Use levels (i.e. 'floors'). Even if you have to modify something in a previous level you can change that with no problem. You can even add levels and reorder them afterwards or move furniture from one level to another. By making each level the only visible one one-by-one you see the steps and by making them all visible you see the complete house. You can't step between the levels with an arrow key and make the selected one the only one visible. To achieve that you would need what Daniels118 suggested: a new plugin that offers a function to cycle through the level tabs and make the selected one the only one visible. It does sound like a useful function if you quickly want to check each level separate from the others. Maybe even have the option to freeze selected levels so they always remain visible when you cycle through the tabs. You could of course export each level to an image and create a booklet like you get with LEGO. Since you have the source for the images it's easy to create a new image if you changed something. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 21, 2026, 11:51:30 AM |
