Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Header for the Floor to ceiling columns » » » » Post: Re: Header for the Floor to ceiling columns |
Print at Sep 21, 2026, 7:46:59 AM |
| Posted by Keet at Nov 17, 2023, 8:07:02 AM |
Re: Header for the Floor to ceiling columns It's still not completely clear but I assume you want to add a footer and header to your column. You can use a box or cylinder to do that: make them bigger than your column and place them at the correct position so the they span outside the column. The footer at elevation 0 of course and the header elevated to wall-height-header-height. Of course you can create any fancy footer and/or header but the process remains the same. You can select all parts of your column and export them. After import you have your column+header+footer as a single 3D model. If you want to change the material names you can get a how-to here: Change_Material_Names.pdf Change_Material_Names_files.zip ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 21, 2026, 7:46:59 AM |
