Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to create a 2D grid and contour map using the Terrain generator plugin » » » » Post: Re: How to create a 2D grid and contour map using the Terrain generator plugin |
Print at Sep 29, 2026, 12:00:44 AM |
| Posted by Puybaret at Nov 7, 2023, 5:41:45 PM |
Re: How to create a 2D grid and contour map using the Terrain generator plugin Here's another trick which consists of transforming the surface to grid lines in OBJ format: - generate the terrain with the plug-in - change its color to black (or any other color you want for the grid) - export it to OBJ format, choosing Export selection option when prompted - open the generated OBJ file with an editor able to handle regular expressions - replace f \d+//\d+ (\d+)//\d+ (\d+)//\d+l $1 $2- import the modified OBJ file in Sweet Home 3D Good luck! ---------------------------------------- ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 29, 2026, 12:00:44 AM |
