Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Making transparent the ceiling of a room, but opaque for sunlight ? » » » » Post: Re: Making transparent the ceiling of a room, but opaque for sunlight ? |
Print at Aug 25, 2026, 12:53:14 AM |
| Posted by Keet at Oct 13, 2023, 7:04:05 PM |
Re: Making transparent the ceiling of a room, but opaque for sunlight ? That's different from what I understood from your first post. From that post I understood you had a camera inside the room and wanted to look through the ceiling to the outside but without the sunlight. Now I understand you want to look from outside into the room (from above) but without the sunlight (like the ceiling blocks the sunlight)? Try to set the clock at midnight, there's no sunlight at that time. Then you can just disable the ceiling and look into it from above and only see the lights you added yourself. If you want to have the refection of your lights onto the ceiling use the same box as I mentioned before but now with only the bottom visible in the color of your ceiling. That way it reflects your lights as if there is a normal ceiling but you can look into it from bove. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Aug 25, 2026, 12:53:14 AM |
