Print at Sep 6, 2026, 3:53:43 AM
Posted by Keet at Sep 27, 2023, 10:56:19 AM
Re: Texturing bugs on some objects.
Weird problem, especially since the furniture that comes with Sweet Home 3D usually doesn't have any problems.
Anyway, you can scale. rotate, and shift each material where you select a texture. (The fields above the "Import" button.)
Did you use one of the default textures or an imported texture? Does the same problem occur when you use one of the default textures that come with Sweet Home 3D? If the same problem doesn't occur with one of the default textures you have found what causes the problem: the texture itself.
