Print at Sep 21, 2026, 9:31:38 AM
Posted by Keet at Sep 12, 2023, 2:02:39 PM
Re: Linux, slow actions in 2D area.
Are you sure that it's the 2D View that is slow? The 3D View updates every time you make a change in the 2D View and usually the 3D View rendering uses more processor power which means more time.
You might want to try the new 7.2 beta version . That is the first version where the 3D View update is halted when you collapse the pane (the small arrows in the pane border) which should prevent the 3D View taking processor power that can be used for the 2D view. When you expand the 3D pane it will render your latest 2D plan without rendering all the steps in between. Especially on slower machines this should speed up things considerably.
