Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 7.2 » » » » Post: Re: Sweet Home 3D 7.2 |
Print at Sep 23, 2026, 10:07:22 AM |
| Posted by dorin at Sep 5, 2023, 9:27:29 AM |
Re: Sweet Home 3D 7.2 That is what I want to say: 1. For X and Y position you have applied the corrections which it is OK. The fixed door frame appear in the correct position when open the door. ![]() 2. For Z it is not the same. The fixed window frame appear upper and upper. After every modify opening I have to manually adjust the elevation. 3. The same happen with Double-hung window when is slides down. ![]() I hope now I've explain correctly what I want to say. Many Thanks for this future version which have a lot of good improvements. I will need same time to discover and correctly use them .---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 23, 2026, 10:07:22 AM |
