Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: House on a land - how to use levels » » » » Post: Re: House on a land - how to use levels |
Print at Sep 9, 2026, 11:34:48 PM |
| Posted by Puybaret at Sep 4, 2023, 9:50:51 AM |
Re: House on a land - how to use levels Levels are stacked upon each other in the 3D view, i.e. when the menu item 3D view > Display selected level is selected, you see the selected level and all the levels below it. If you created the land level after the level where you house is designed, you should probably reorder them to see your house on the land: double click on the tab of its level and change its order with the arrows on the right of levels table show in the level modification dialog box (these arrows are available only for levels at the same elevation as another level). You could also select the menu item 3D view > Display all levels, but it's still interesting to understand how levels are handled when the option 3D view > Display selected level is selected. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 9, 2026, 11:34:48 PM |
