Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Generate roof plugin » » » » Post: Re: Generate roof plugin |
Print at Sep 24, 2026, 11:09:56 AM |
| Posted by Keet at Aug 30, 2023, 6:05:35 PM |
Re: Generate roof plugin A quick look shows several inconsistencies: Check you preference settings for new levels because the Roof Generator generates a level 'Roof-gen' with elevation 365. If you have that set in your preferences (wall-height+floor-thickness=365) than that is the cause. (Dorin can determine if it's because you have a level height of 1 on level 0 that could cause the Roof Generator to use a default.) Your level 0 is 1 high, should be 300 with walls 300 high. Change the Roof-gen level elevation to 300 and the probem is fixed. (double click on the level tab.) @Hans: good find, I missed the different wall heights. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 24, 2026, 11:09:56 AM |
