Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Export using the name in the plan » » » » Post: Export using the name in the plan |
Print at Oct 6, 2026, 4:09:12 AM |
| Posted by Keet at Aug 15, 2023, 7:19:13 PM |
Export using the name in the plan This one might be relatively easy to implement (I hope): When exporting a selection of objects name the g groups as named in the plan instead of the original object name. Preferably optional but set as the default. For example a box when exported has 6 g lines like top_1, left_2, etc. Since the mtl reference (usemtl line) already identifies each side the g name is useless. What IS useful is naming the 6 sides using the name in the plan. Without changing a new box that would result in 6 lines like box_1, box_2, etc, each followed by the usemtl line for that side. Using this type of naming would allow a group of multiple boxes to be identified individually in the OBJ file by their g lines according to the names you assigned to each box. Currently 3 boxes in an export generates lines with top_, left_, etc. in triple no matter what names the boxes have in the plan. This can make it very difficult to distinguish one from the other when editing a large obj file. By using the name in the plan you can decide yourself if you want identical names or not. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 6, 2026, 4:09:12 AM |
