Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Create a room between rooms » » » » Post: Re: Create a room between rooms |
Print at Oct 6, 2026, 1:53:59 AM |
| Posted by Keet at Aug 9, 2023, 2:26:40 PM |
Re: Create a room between rooms Great tutorial and this works for what most users want to accomplish for a terrain. Since you still need walls it will be very tricky to create side-lines or thin borders along a road because it's very difficult to keep an even space between two thin and close together walls. Advise for anyone who is going to try this: first save a copy of all walls on a separate level that you make invisible. That way you can safely delete the walls that need to be removed for the example to work and you can copy them back from the saved walls if needed. I still hope for an added option in the future that will make it as simple as double-clicking within an open space. That will allow a single thicker wall to create the small space for a border line that can be filled with a room. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 6, 2026, 1:53:59 AM |
