Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Create a room between rooms » » » » Post: Re: Create a room between rooms |
Print at Oct 6, 2026, 4:58:33 AM |
| Posted by dorin at Aug 9, 2023, 9:12:23 AM |
Re: Create a room between rooms After you use the tinny walls for define the land near the river, DON'T delete the walls (yet). Connect them around the river then use AutoDimensioning plug-in to generate build area around walls. This will generate a room outside the walls. Now you could delete the tinny walls and probably the gap will disappear. Probably will be on different level but you could cut/paste the room(s) where you need. Remember: Will generate build area around ALL walls at that level (connected or not) so you will have to keep only needed ones. Or maybe could be used as tinny rooms?? I don't know! You have to test. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Oct 6, 2026, 4:58:33 AM |
