Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: transparent models from walls in YafaRay, rendering fails » » » » Post: transparent models from walls in YafaRay, rendering fails |
Print at Sep 21, 2026, 5:02:18 AM |
| Posted by GaudiGalopin3324 at Jul 28, 2023, 2:49:47 PM |
transparent models from walls in YafaRay, rendering fails Hi everybody. I can't solve the issue with the new version, the SunFlow and YafaRay traces. I like YafaRay, the rendering goes fast, the picture turns out without sharp spots. But this trace is in conflict with the created models from the walls. If the model has the specified transparency, then the render via YafaRay turns out to be opaque, and the greater the transparency, the darker the picture. Ready-made glass models, for example, a shower enclosure made of SH3D and all sorts of glass vases render well. In the pictures in the application, I made a curtain model in SH from the walls and assigned it 70% transparency, saved it in OBJ. Assigned a white skin texture. In Sunflower, translucency with a white matte shade is obtained, but not in YafaRay. Straight walls (OBJ) with transparency and white texture also turn opaque and gray. And the finished glass from the library turns out to be transparent in both versions of the trace. What can I do to use YafaRay? SunFlow https://www.mediafire.com/view/ltehzlx5i48tdgu/SunFlow.jpg/file YafaRay https://www.mediafire.com/view/sdncj1jlcpl6u7v/YafaRay.jpg/file |
Current timezone is GMT Sep 21, 2026, 5:02:18 AM |
