Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: One way mirror window » » » » Post: Re: One way mirror window |
Print at Sep 15, 2026, 8:05:10 AM |
| Posted by Keet at Jul 20, 2023, 3:00:03 PM |
Re: One way mirror window For all who want to understand what happens with the combination of glass and mirror in the example I presented. You first have to understand the faces (sides) of a box. A face has only one side. This means you can see it only from one side. From the other side it is like there is nothing. You could create a window privacy film by just texturing the front as a mirror and make the other sides invisible. After export/import you will have a 'real' film since it has no depth. You could stick this to an existing window. Adjust the transparency of the mirror if you want it to be a little glass-like transparent. (The d parameter in the mtl file.) The obj and mtl file I presented still has all sides where the back face for the inside is made glass and the front face is made a mirror (with no transparency). The border sides are left as borders. The result is that from the back side you are looking through glass and from the front side you are looking at a mirror. Luckily we often have multiple options in Sweethome3D. In this case the option of using only a single face as a film has the advantage that you can stick it to any existing window to achieve the same effect. The option with combined glass and mirror sides is perfect if you are custom creating your windows. In that case you could make the borders glass too if you want. In the original French post bdfd explained with images what I forgot: you can only see some effects when creating a photo and only in the higher rendering modes. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 15, 2026, 8:05:10 AM |
