Print at Sep 20, 2026, 2:43:49 PM
Posted by Keet at Jul 18, 2023, 9:19:08 AM
Re: Stairs U shaped two landings
The walls you can split and adjust in height.
For the cutout in the floor you will have to add your staircase to a Furniture Library. In the Furniture Library you can customize the cutout in the floor. The cutout is defined as an SVG path and you can download a pdf here that explains how that works. It looks difficult but once you understand how to draw a path it's simple.
To create your own Furniture Library you need to download and install the Furniture Library Editor .
