Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Disabling offscreen check in the application » » » » Post: Re: Disabling offscreen check in the application |
Print at Sep 24, 2026, 10:34:15 AM |
| Posted by Puybaret at May 10, 2010, 11:37:55 AM |
Re: Disabling offscreen check in the application I'm glad this solution was helpful for you. You're the first user to give some feedback about it. How can you know it's slower since it didn't work before? Is there a command line option I could pass in to my installed version to disable this check? Yes, add the following option to the java command:-Dcom.eteks.sweethome3d.j3d.checkOffScreenSupport=false---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 24, 2026, 10:34:15 AM |
