Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Create room from walls » » » » Post: Create room from walls |
Print at Sep 21, 2026, 8:57:39 AM |
| Posted by jlw0003 at Jul 8, 2023, 3:37:30 AM |
Create room from wallsSomeone please help me. I love this program, but I am still learning. I have spent hours playing with this problem and searching help and forums, to no avail. I have often created "rooms" (usually outdoor areas) by first drawing walls with varying shapes and then double clicking inside to create the room. With odd shapes I often find that there are gaps in the walls that must be connected before the room can be created. I often spend a lot of time searching for these breaks in the walls. Is there any easy way to identify where the breaks are? I have tried selecting all walls and using the Join Walls function or the Connect Walls plug-in. That does not seem to work--the Join walls menu item is grayed out. Connect walls often results in unusual connections. I have usually resorted to selecting two walls at a time and trying th Join Walls. Again, often grayed out indicating that the walls are already joined (sometimes when I see that they are not!) I have now created an area that I have looked at from every point possible and find that there are no gaps, yet when I double click inside the area nothing happens at all. If I double click on the walls it creates a "room" the size of the walls themselves. I have installed the Autodimensioning tool and used it to add "built areas with outlines" (no walls selected) and it also shows a "room" in the walls themselves, but missing three of the walls. I double check these walls and the program indicates that they are all joined. I am at a loss! How do I fix this. Thanks in advance for any help. |
Current timezone is GMT Sep 21, 2026, 8:57:39 AM |
