Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Import Furniture Problem » » » » Post: Re: Import Furniture Problem |
Print at Sep 26, 2026, 10:25:05 AM |
| Posted by snmavronis at Jul 3, 2023, 7:51:52 PM |
Re: Import Furniture Problem I checked that but mine under Windows 11 Pro 64bit was already off. I experimented turning it on because you can add an app to "not be blocked" if you use controlled folder access. When I went there it gives you a blocked list and it was empty so nothing was blocked at all by this setting so I turned it back off. I use a combination of Windows Defender and Malwarebytes Premium. Neither of them have blocked SH3D ever. Thank for your suggestion but it doesn't apply in my case. Also, just to note - Upon opening SH3D I can do a Save-As and it gives the browse dialog box to type in a filename, but afterwards trying it again does nothing so this is pretty strange behavior because everything was working fine up until some point last month. I even tried running SH3D as Administrator after modifying the shortcut properties but no change. Maybe there is a conflict with a recent Windows Update or another app being updated on my system that happened in the meantime. I even tried installing JAVA just in case but it had no effect so I uninstalled it. Maybe I'll get lucky with a future version of SH3D before this is fixed. ---------------------------------------- Steve N Mavronis - Retired PC Tech |
Current timezone is GMT Sep 26, 2026, 10:25:05 AM |
