Print at Sep 21, 2026, 12:43:31 PM
Posted by Keet at Jul 2, 2023, 3:53:00 PM
Re: Read back generated shape
I have no problem writing the code myself although I'm not familiar with Java. I am a C# developer (with a little PHP,Html/Css/JavaScript on the side) and from what I understand the differences with Java shouldn't give many problems. My current problem is I don't have a development environment for Java. I'm in the process of installing a new machine on which the full JetBrains development suite will be installed, which includes the environment for Java. It will be a few weeks before I can start with that because I'm way too busy.
Expect it to be several months before the first custom code will appear. Many of my wishes on the list I will be programming myself because I don't expect them to be introduced anytime soon if ever. Emmanuel can integrate them if he wishes after the code has proven itself.
The Shape Generator is probably one of the first because it should be relatively easy but I will try to extend it to allow more points. The biggest one is probably an extension of the UI where I want 2 extra panes on the right side like the panes on the left but with lists of the walls and rooms. Of course with full select and modify options tongue
Thank you for your offer to help. When I start I will probably need it.
