Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Textures attached to boxes sometimes stuck at 45 deg angle » » » » Post: Re: Textures attached to boxes sometimes stuck at 45 deg angle |
Print at Aug 19, 2026, 4:53:51 AM |
| Posted by Keet at Jul 1, 2023, 8:21:50 PM |
Re: Textures attached to boxes sometimes stuck at 45 deg angle If you can assign a texture to each side individually you can select the 'wrong' side and rotate the texture to fit. If that doesn't work you will have to change your object in FreeCAD to make sure the texture is aligned correctly, which is probably the reason for the problem. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Aug 19, 2026, 4:53:51 AM |
