Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Faces of the wall » » » » Post: Re: Faces of the wall |
Print at Sep 20, 2026, 4:13:18 PM |
| Posted by Keet at Jun 26, 2023, 6:04:34 PM |
Re: Faces of the wall I'd like to extend on that feature wish, one I have on my very long list of wishes When exporting a wall we get 6 faces in the export, Left start-side, left, left end-side and the same three for the right side. By editing the obj file you can get 6 different properties but it's no longer a wall when you import it. For a wall I'd like to see 8 properties similar to the properties of a box: leftstart, left, leftend, rightstart, right, rightend, top, bottom. That way we can texture each face while the object remains a wall. This will also solve the problem with the distorted textures on the wall ends. With a separate property you can adjust it for just the ends so it looks right. The separate top and bottom are especially usefull when you use a wall to create a part for custom furniture and it gives the possibility to make each face invisible. Separating the properties might be necessary anyway if the wish from crackwood01 is implemented. I never used baseboards but I would have expected the default behaviour with baseboards to include the sides. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 20, 2026, 4:13:18 PM |
